I have a 1991 Honda Accord LX 5 spd. 237,000 mlg. My first problem Is a rough/erratic idle , it's fine while it warms up if it's cold. But after a minute or two without touching the gas, the engine surges to 1,600RPM and back to 900 RPM.Over and over and over again, all the time. It is not noticeable while driving unless it is in first gear with you foot off of the gas. Checked for intake and exhaust leaks etc. What to do? Second my chiltons manual says my brake rotors should come off by removing the caliper and two simple screws. Not so. I had the tranny and axles replaced awhile ago they may have swapped some replcement crap in form their yard. I've removed the axle nut and the caliper how do i get this rotor off? fyi there aren't any screws on the front of the rotors
Apr 15, 2006 at 2:34 AM
