transmission is jerking
CHARLIE49
96 accord honda automatic transmission is jerking into and out of gears when transmission shifts - did not match any documents
Sep 3, 2007 at 6:48 PM
  • 75,988 POSTS
[quote:1260984276="Charlie49"]96 accord honda automatic transmission is jerking into and out of gears when transmission shifts - did not match any documents[/quote:1260984276]
The computer decides when the transmission moves, by getting input signals from these sensors-CTS/TPS/VSS/Brake signal and in turn decides what solenoid/s to be activated. Overall it means with out the computer the tranny w/n function correctly.
Sep 3, 2007 at 10:00 PM
CHARLIE49
[quote:3d72f92cb5="rasmataz"][quote:3d72f92cb5="Charlie49"]96 accord honda automatic transmission is jerking into and out of gears when transmission shifts - did not match any documents[/quote:3d72f92cb5]
The computer decides when the transmission moves, by getting input signals from these sensors-CTS/TPS/VSS/Brake signal and in turn decides what solenoid/s to be activated. Overall it means with out the computer the tranny w/n function correctly.[/quote:3d72f92cb5]
I want to thank you for the information you sent me. I will have the installer check the computer for any repair signal that are needed. Again Thank you.
Sep 4, 2007 at 12:52 AM
