96 accord honda automatic transmission is jerking into and out of gears when transmission shifts - did not match any documents
Tuesday, September 4th, 2007 AT 1:48 AM
MECHANIC
The computer decides when the transmission moves, by getting input signals from these sensors-CTS/TPS/VSS/Brake signal and in turn decides what solenoid/s to be activated. Overall it means with out the computer the tranny w/n function correctly.
SPONSORED LINKS
Tuesday, September 4th, 2007 AT 5:00 AM
CHARLIE49
MEMBER
The computer decides when the transmission moves, by getting input signals from these sensors-CTS/TPS/VSS/Brake signal and in turn decides what solenoid/s to be activated. Overall it means with out the computer the tranny w/n function correctly.[/Quote:3d72f92cb5]
I want to thank you for the information you sent me. I will have the installer check the computer for any repair signal that are needed. Again Thank you.
