Tacometer jumping around
IBM3554
92 Accord EX 2.2, 189,000 miles. On cold mornings the tacometer jumps around while accelerating. I can feel the engine surging slightly when this happens. Could it be a ignition problem. What component sends the signal to the tac? Thanks
Apr 11, 2007 at 8:50 AM
BRUCE HUNT
  • 3,754 POSTS
If the engine is surging the tach should jump accordingly. The surging is generally related to a vacuum leak or air in the cooling system. Even a lack of coolant can cause this.
Apr 11, 2007 at 9:57 AM
  • 75,988 POSTS
[quote:c5e4a938a6="ibm3554"]92 Accord EX 2.2, 189,000 miles. On cold mornings the tacometer jumps around while accelerating. I can feel the engine surging slightly when this happens. Could it be a ignition problem. What component sends the signal to the tac? Thanks[/quote:c5e4a938a6]
When the coil secondary winding collapses the control module off signal will go to the Tachometer as an indication of engine speed RPM.
Apr 11, 2007 at 1:40 PM
