suspension question
HONDA ACCORD
GREG23
i have a 1993 Honda Accord Wagon LX w/ 175k miles. anytime i hit a bump (big or small) i hear a clanking noise from my front driver side wheel. i jacked the car up and grabbed the wheel at the top & btm and tried to move it back and forth, and it did not move. however i then i grabed the wheel from right to left and tried to move it and it moves a little.. about an inch or less.. any idea of what this might be and any idea on about how much this might cost me to take it to a shop and have them fix it? thanks for all your help !!! i love your website!!
Aug 13, 2006 at 7:10 PM
BRUCE HUNT
  • 3,754 POSTS
Kind of hard to judge side play. I look at tire wear and handling of the car. Now the noise could be coming from a loose and worn stablizer in the front. It is often difficult to find without putting the car on a rack to let the suspension system loosen up. Generally, when you hit a bump, small ones as well, the car actually is off the ground. If you can't find it, take it to a mechanic and have him put it up and look for it. Have him show you what he found.
Aug 22, 2006 at 2:42 AM
AEGISKNIGHT
I'm not sure what the "clank" sound you hear is, but I do know that for civics and accords, the suppension is normally tight since they ride low. If you could only get it down to about 1 inch or so, how hard was it to get it there? If it takes a lot (lets say you weigh 200 lbs and are in shape) of effort to push it, then I wouldn't worry about it.
As far as actual cost, the parts for both sides of the front end are approx. $120.00 each, labor varies from $50.00-$100.00 per hour depending on who you take it too. I would estimate about 2-4 hours for both to be removed and installed.
Keep in mind that when you replace the shock absorbers or springs, the car will be out of alignment, which cost about $100.00.
Aug 30, 2006 at 12:58 PM
