Squeking sound when car starts
ACTIONJ4614
I have a 92 honda accord with 213,000 miles on it and recently had the timing belt and tensioner replaced about 4 months ago. For about two weeks now I hear a squeking sound everytime I start the car, then is goes away. Should I have the repair shop who replaced the timing belt check it out?
Mar 13, 2006 at 11:47 AM
VANDRAGON
  • 298 POSTS
was it making the noise before? i would take it back for sure. it could be wrong belt, wrong tention or they may have got oil on one of the pullies. also check the power steering fluid.
Mar 19, 2006 at 2:56 AM
BRUCE HUNT
  • 3,754 POSTS
When they put the other belts back on they tensioned them they may have not set the tension correctly on the power steering or the alternator. Try belt dressing on them to see if that stops it and if it does adjust the belt tension.
Mar 20, 2006 at 6:20 AM
ACTIONJ4614
Thank you very much for the response, I will have it checked out asap.
Mar 20, 2006 at 9:11 AM
