1996 Honda Accord Speedometer and Defrost
MARTYLINGO
We have a 1996 Honda Accord and the speedometer works intermittently. Also, the defrost doesn't blow at the window. I am told the repair manuals don't cover that. Any ideas on what it might be and how to fix it?
Apr 29, 2007 at 1:12 PM
BRUCE HUNT
  • 3,754 POSTS
The speedometer sounds like a short. The could be a loose connection, either a wire, connector, or a circuit board problem. You may have to do some digging to find the problem and it will probably turn out to be the speedometer itself or the Variable Speed Sensor. Tough one to track down.
The defrost, it the motor of the fan blowing or is it blowing and not getting air on the windows. If the latter is the case, it could be the knob on the dash is slipping or stripped. Check out the knob and after that you are in to other under the dash components for the defrost. If that is the case, deal with both of the problems at the same time.
Manuals don't necessarily cover the problem you have but they cover the removal and replacement of the components that you are talking about.
Apr 30, 2007 at 2:32 AM
Suggested Repair
For the intermittent speedometer, inspect for a short or loose wire, connector, or circuit-board connection, and suspect the speedometer or variable speed sensor if those check out. For the defroster, determine whether the fan runs but air does not reach the glass; if so, check for a slipping or stripped dash control knob, then inspect the related under-dash components. Address both issues together if the dash must be opened, using a manual for component removal and replacement.
Conversation Summary
The owner of a 1996 Honda Accord reports an intermittent speedometer and a defroster that does not blow air onto the window, and notes that repair manuals do not specifically cover the symptoms. The expert says the speedometer issue may be a short or loose connection and could involve the speedometer or variable speed sensor. For the defroster, the expert asks whether the fan is running and suggests checking a slipping or stripped dash knob before inspecting under-dash components.
