1992 Honda Accord Steering Wheel Shake
HONDALADY
My car is a 92 honda accord ex with about 100,500 miles on it or so (give or take a few miles) it has a 4 cylinder engine. (sorry not sure how many liters can come back and post that if i need to) I get in my car and start it up and the steering wheel gets to shaking pretty bad with the air conditioner on. it does it a little with the ac off but alot with it on. i was told that the motor mount bolts might be going bad. would that be a correct diagnosis?
Aug 28, 2007 at 9:18 AM
88HONDAACCORD
  • 13 POSTS
well it could be the motor mount is broken or as a result of lower tire pressure and also could be low idle and if it is low idle dont hide a higher idle of many other problems it could be but check those first three problems
Sep 25, 2007 at 10:12 PM
BRUCE HUNT
  • 3,754 POSTS
Listening to your comments I am going to wager that the vehicle is idling to low. Your vehicle should be idling at about 750 rpm + or - 50 whether the ac is on or not.
Sep 27, 2007 at 6:36 AM
HONDAPRO
You know my car did the same thing. I have a 90 accord F22A-4 with about 40k miles on it. But it turned out to be the front motor mount was destroyed. We pulled the mount and it fell apart. Still had a fairly rough idle and drive after words with n without AC.. that turned out to be the EGR vavle was going bad.
Sep 30, 2007 at 10:55 AM
HONDALADY
thank you very much for the information. I will check into those things.
Oct 4, 2007 at 1:30 AM
HONDALADY
Ok did you mean the motor mount bolts or the entire motor mounts? you ment the bolts and rubber grummets right?
Oct 4, 2007 at 10:49 AM
Suggested Repair
Check idle speed first; it should be about 750 rpm with the AC on or off. Also inspect the motor mounts and tire pressure, which were suggested as other possible causes of the steering-wheel shake.
Conversation Summary
The owner of a 1992 Honda Accord reported steering-wheel shake that was mild with the AC off and much worse with it on, and asked whether failing motor-mount bolts could be the cause. Replies suggested a broken motor mount, low tire pressure, or low idle. The expert suspected the idle was too low and said it should be about 750 rpm whether the AC is on or off. Another owner described a similar Accord issue caused by a failed front motor mount and a bad EGR valve. The owner planned to check those items and asked whether the mounts themselves, not just the bolts, should be inspected.
