1997 Honda Civic Idle Surging
UDIT99
Hona Civic 1997 Ex 1,24,000 miles
Hi
I just had my Honda Civic 97 Ex VTEC engine replaced with another Honda Civic 98 VTEC Engine. The salvage guy said according to some books he consulted, they're the same and they're interchangeable. So thie mechanic who was willing to do it for me replaced the engine and the car works now but there is one problem. When idling, the Engine starts revving up and down without anyone even touching the accelerator. He says his "computer" cant figure out whats wrong and he's having a difficult time figuring out this problem. He gave me two pointers:
1. He had to replace the O2 Sensor from the old engine to the newer engine since the newer engine sensor broke at the time of delivery. Possibly mismatching ohms he said
2. The wiring from the car computer to the engine wasnt exactly the same. There was one extra wire .. possibly on account of the newer engine being a 1998 than a 1997. Since the newer wiring didnt fit into the computer, he replaced the engine wiring with the older engine's wiring
Could wither of these have caused this problem ?
Has anyone experienced this ?.. any suggestions I can pass on to the mechanic ?
Sep 21, 2006 at 10:26 AM
BRUCE HUNT
  • 3,754 POSTS
If it does it all the time have him check the intake manifold for a leak. A leak in the intake like say the gasket will cause more air to get in and confuse the computer. The result is the engine surging up and down.
Oct 24, 2006 at 1:11 AM
Suggested Repair
Check the intake manifold and gasket for a vacuum leak, which can let extra air in and cause the engine to surge at idle.
Conversation Summary
The owner of a 1997 Honda Civic EX had the VTEC engine replaced with a 1998 Civic VTEC engine. After the swap, the engine surges up and down at idle. The mechanic reused the old oxygen sensor and the original engine wiring because the 1998 harness did not match the car's computer. The expert recommends checking the intake manifold for a leak, such as a bad gasket, which can admit extra air and confuse the computer.
