rear wheel bearing
GORGEOUS
honda accord ex 4 cylinder...I need to change my wheel bearing for the rear and I can't figure out how to change it..is there a way that I can actually do it at home without getting it fix at the shop?
Sep 6, 2007 at 11:07 AM
MERLIN2021
  • 17,250 POSTS
If I knew what year it is I could help, but with a name like gorgeous, can you chance a broken nail? This could get ugly...
Sep 6, 2007 at 11:17 AM
BRUCE HUNT
  • 3,754 POSTS
Very simple job. Lift the car as if to replace the tire. Remove the tire. Take the two back bolts off the caliper and remvoe the brake caliper. Hang it up with a wire. Take out the two screws that hold the rotor in place. Remove the rotor. Remove the nut on the axle. Your may have to use a hammer and punch to loosen the lock on the nut. Pull off the hub and replace. Reverse installation remembering to use the punch to lock the nut in place on the axle.
Sep 7, 2007 at 2:51 AM
