R&R two screws on front rotors
JAKESJAKES
  • 7 POSTS
2000 Honda Accord Ex-6 3.0L 4 dr sedan---
First time changing my front rotors and front brakes. Can I R&R the front two rotor screws on each front rotor without buying a "special tool"? I tried with a large Phillips screwdriver, but no luck. Suggestions? Thank you for your help.
Oct 10, 2006 at 6:19 AM
BRUCE HUNT
  • 3,754 POSTS
Here is the deal. You can try a huge phillips bit and a wrench to crack them open. I would suggest a little "liquid wrench" sprayed on first and let soak in. Another that works real well is an impact screwdriver. Very cheap that you hit with a hammer to force the screw to turn.
If by chance you twist them off you can drill them out and retap OR as a last resort skip the screws and as is obvious the rim easily holds the rotor in place.
Oct 11, 2006 at 6:20 AM
JAKESJAKES
  • 7 POSTS
[quote:bf2a61cd67="Bruce Hunt"]Here is the deal. You can try a huge phillips bit and a wrench to crack them open. I would suggest a little "liquid wrench" sprayed on first and let soak in. Another that works real well is an impact screwdriver. Very cheap that you hit with a hammer to force the screw to turn.
If by chance you twist them off you can drill them out and retap OR as a last resort skip the screws and as is obvious the rim easily holds the rotor in place.[/quote:bf2a61cd67]
Bruce-thank you.
Oct 11, 2006 at 6:36 AM
