question abt my 94 Honda Accord LX(140k)
REEJAREJIN
Someone pls tell me wht problem with my car.
I fixed my A/c and both the fans last month..bcoz before i had a problem like the heat indicator goes up. Then the mechanic told it's due to the bad fans.. so i changed both the fans.. but the problem is now also when i stopped in the trafic or traffic signal for some time..the heat indicator again goes up and when i put the a/c there is no problem,it goes down. Also after i switch off the engine ,there is sound of fan operating ..What the problem..It is very helpful..pls asap
Feb 20, 2006 at 2:25 AM
FISHERMAN
  • 937 POSTS
check the temperature sensor...
when your A/C its "on" the engine need more cooling thats why both fans are on, but under normal conditions just one of them keeps on and off, identified which one its the a/c fan and check if the anotherone its working good.
Feb 20, 2006 at 5:55 AM
