Hi, I have a 98 Honda Accord Coupe Ex. My passenger window will not stay all the way shut. When I press the switch to roll up, it goes all the way up and then drops down about a 1/4 of an inch or so. If I hold the switch (which I don't like to do) the glass will rattle but it never goes up all the way. I took the door panel off studied it for about half an hour and watched everything the assembly inside did when I used the switch. I even compared it with the driver side, which does work and couldn't find any difference. The cheapest price I've gotten just to look at it was $70 so that's out of the question for now, meanwhile every time it rains my seat gets wet. I would really like to fix it myself but I can't figure it out. The other problem I have is that whenever I first drive my car after it's been parked for a little while, there's alot of resistance behind the gas pedal for some reason. I have to apply a good bit of pressure just to break the jam and I end up practically flooring it every time. I would really appreciate any assistance you could offer. Thanks.
Jun 14, 2007 at 4:59 AM
