clunking felt in the gas pedal after driving about fifteen minutes
150,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
DANJONES
So this problem I would consider a "clunking"
Now the details
•starts happening after about fifteen minutes of driving or "warming up".
•can be felt in the gas pedal and mostly under the floorboard of the driver, but can be felt in the passenger floor as well.
•once it begins the "clunking" it only happens when pushing on the gas pedal, and stops when letting off the gas.
•once the clunking begins it is felt at any speed, whether five mph or sixty mph. if anything it is less pronounced at higher speeds, but still there.
•happens in all gears D4, D3, 2, 1.
•if I put it in neutral when it is happening and rev the engine it does not occur or happen in neutral, but if I put it back in drive it starts happening again.
•feels more dominantly on the front passenger wheel area.
Any ideas? Thanks much for even reading this and hopefully taking the time to give input.
Dec 10, 2016 at 5:49 AM
CARADIODOC
  • 34,415 POSTS
The place to start looking is at the exhaust pipe hangers. The rubber isolators soften when they warm up and will allow more flexing. A pipe may be rubbing against a heat shield or metal bracket.
I do not know where the anti-sway bar inner bushings are located, but if they are on the engine-side of the firewall, see if the clunking stops when you turn the steering wheel as little as a quarter turn either way. If the noise stops, suspect those bushings. When turning, even slightly, one wheel moves down and the other moves up, thanks to an alignment angle called "caster". Those movements put a twist on the anti-sway bar, and pressure on the inner bushings. If the noise stops, you can verify this with the car on a drive-on hoist. Wrap your fingertips lightly around the anti-sway bar, then bounce the car up and down just a little, by hand. You will feel the looseness and thumping between the bar and the bushings.
You an get the same thumping with other anti-sway bar mounting designs, and on some cars the outer ends use rubber bushings instead of the more-common links. The hole through the center of those bushings can become worn larger and allow the bar to bump up and down inside it.
Your car uses outer links with a pair of ball and sockets on each one. Those will cause rattling too, but those are not normally affected by time or temperature.
There is a tool you might be able to borrow or rent from an auto parts store that borrows them called the "Chassis Ear". It is a set of six microphones, a switch box, and headphones. You clip the microphones to suspect points, then drive around while listening with the headphones. You can move the microphones around to zero in on the source of the noise. Be aware that many mechanics have never seen or even heard of this tool. Suspension and alignment mechanics use it to find rattles, squeaks, and other noises.
Dec 10, 2016 at 6:48 AM
