2001 Honda Accord Lights Dim on Bass
IEATGLUE6457
i have a 2001 honda accord with a 2.3L engine. the alternator is rated at 80 amps. i recently put in a top of the line stereo system with two amplifiers each drawing 40 amps peak. using only one amp, everything runs fine and sounds ok. as soon as i turn on my subs (using the other amp) the lights dim, and the sound distorts terribly. i know this is because my amplifiers are drawing more power than my alternator can provide, so everything drops. i currently have a capacitor installed, so thats helping the load. i looked into rebuilding the alternator, and i know that that would help, but what else can i do? would adding more capacitors or batteries lessen the workload on the alternator? again, i only have the problem when the bass hits are strong, so its not a constant strain.
Nov 5, 2007 at 9:05 AM
  • 75,988 POSTS
Add more capacitors and fabricate a dual battery system.
Aug 25, 2020 at 5:51 AM
BRUCE HUNT
  • 3,754 POSTS
There is really only two solutions. Add a second alternator or increase the size of the alternator. I will let it go at that because I will say something I shouldn't.
Suggested Repair
Upgrade to a higher-output alternator or add a second alternator. Extra capacitors and a dual-battery system were also suggested to help cover strong bass peaks.
Conversation Summary
A 2001 Honda Accord owner with an 80-amp alternator added two amplifiers that draw about 40 amps peak each. With one amp the system is fine, but strong bass from the second amp dims the lights and distorts the sound despite a capacitor. Experts recommended a larger or second alternator, with additional capacitors and a dual-battery setup also suggested for peak loads.
