Oil in the spark plugs
EAST4188
i have a 95 honda accord ex. recently it started leaking motor oil into the spark plugs causing it not to start up and when it does it will turn off shortly after. any suggestions on how to fix this?
my email is nathan.east88@gmail.com
thanks
Jul 7, 2007 at 9:07 AM
BRUCE HUNT
  • 3,754 POSTS
Take off the four bolts on the valve cover. Get a new valve cover set. It should come with new plug well seals. Very easy job. You probably might need to replace the plugs and wires. Plugs can be damaged and the wires should not be soaked with oil.
Jul 8, 2007 at 6:36 AM
