no sprark honda accord 94 dx
JAVIER_JOSUE
i already check the coil its have voltage and a resistance between 22,000 and 0.7 ohms
but wen i hook a bulb to the negative signal and crank the engine the bulb doensnt blink what do i do to know if its the wiring or the distributor
Nov 17, 2007 at 3:23 AM
BLACKOP555
  • 10,386 POSTS
well i would check for carbon build up on distributor and rotor for carbon build up or cracks, or a worn rotor. also could have a bad ignition module or crank position sensor.
Nov 17, 2007 at 2:42 PM
