2003 Honda Accord Cooling Fans Loud
SOULJAHSLIM305
MY GIRL HAS A 2003 HONDA ACCORD 4CYCLINDER ENGINGE WITH 70000+ MILES. EVERYTIME HER ENGINE FANS ON HER CAR COME ON U HEAR THEM. THEY ARE BLOWING LOUDER THEN THEY WHERE ABOUT A MONTH AGO. ALSO THEY ARE CONSTANTLY TURNING ON N OFF, I DONT KNOW IF IT WAS DOING IT LIKE THAT BEFORE CUS YOU COULDNT HEAR THEN COME ON AND OFF. COULD SOMETHING BE WRONG WITH ONE OF THE FANS LIKE A BEARING OR CAN SOMETHING ELSE BE BAD?
May 30, 2007 at 3:02 PM
2CARPRO JACK
  • 11,533 POSTS
be sure it is full of coolant and the thermostat is working properly. Reach in (key off) and spin the fan to see if the bearings feel bad. Can honestly say I dont ever remember changing a Honda cooling fan. Does it have 2 fans? might be hearing the a/c and the cooling fan running. The a/c fan will cycle if the pressure is too low or high
May 31, 2007 at 1:09 AM
Suggested Repair
Confirm the cooling system is full of coolant and that the thermostat is working. With the key off, spin the fan by hand to check for bad bearings. Also determine whether both fans are running, since the A/C fan can cycle if system pressure is too low or too high.
Conversation Summary
The owner of a 2003 Honda Accord with over 70,000 miles reports that the engine fans are louder than they were a month ago and are constantly turning on and off. The owner asks whether a fan bearing or another component could be failing. The expert recommends checking the coolant level and thermostat, spinning the fan with the key off to feel the bearings, and considering that both the cooling and A/C fans may be running, with the A/C fan cycling due to low or high pressure.
