My Honda is won't come out of gear when in reverse
AMY_SARA
Hi, I have a 1999 5 speed manual transmission with 95K miles.
Recently, when I put the car in reverse and my foot on the clutch and the car is completely stopped, I can't get the car out of reverse and the engine stalls.
I have to turn off the car, turn it back on to get the car out of reverse. If I get the car out of reverse before I come to a complete stop, I am ok.
I am a female, if I go the repair shop and explain this, I fear I am going to be told I need a new transmission and or clutch. An outside opinion would give me some confidence.
Thanks
Aug 26, 2007 at 12:18 AM
SERVICE WRITER
  • 9,123 POSTS
At 95K, I doubt you need a clutch or transmission. It sounds more like a worn linkage or adjustment issue to me. I assume the master cylinder fluid for the clutch is full.(?) It may not hurt to check the pedal height to make sure it is correct and adjust as necessary:
https://images.2carpros.com/forum/automotive_pictures/30961_honpedht_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_honpedhtadj_1.jpg
But I would be sure to check these bushings for excessive wear:
https://images.2carpros.com/forum/automotive_pictures/30961_honbush_1.jpg
Aug 26, 2007 at 12:39 AM
