Mushy Brakes
JOHNNYEJ
1990 Honda Accord EX, 175,000 Miles 2.2L? engine. When I run the A/C and it gets hot outside the brakes get very soft, and after a short period of time while applying them will bottom out. When it is cool outside, this is no problem with or with out the A/C on. How can I fix?
Jul 16, 2007 at 9:48 AM
BRUCE HUNT
  • 3,754 POSTS
That car has the booster system on the brakes I believe and it sounds like a vacuum problem. Does the brake fluid reservoir ever get low?
Jul 17, 2007 at 9:40 AM
JOHNNYEJ
Brake fluid at normal level.
Jul 17, 2007 at 9:42 AM
BRUCE HUNT
  • 3,754 POSTS
If the fluid stays at the same level and does not drop I would suspect the booster.
Jul 17, 2007 at 9:43 AM
JOHNNYEJ
Thanks Bruce, Where is the booster located and is this a possible FIY project?
Jul 17, 2007 at 9:45 AM
BRUCE HUNT
  • 3,754 POSTS
The booster should be behind the master cylinder. I would look at the vacuum line for any problems. Leaking is my suspicion.
Jul 17, 2007 at 9:50 AM
JOHNNYEJ
Thank you, I'll check it out.
Jul 17, 2007 at 9:51 AM
