1990 Honda Accord Soft Brakes with A/C
JOHNNYEJ
1990 Honda Accord EX, 175,000 Miles 2.2L? engine. When I run the A/C and it gets hot outside the brakes get very soft, and after a short period of time while applying them will bottom out. When it is cool outside, this is no problem with or with out the A/C on. How can I fix?
Jul 16, 2007 at 9:48 AM
BRUCE HUNT
  • 3,754 POSTS
That car has the booster system on the brakes I believe and it sounds like a vacuum problem. Does the brake fluid reservoir ever get low?
Jul 17, 2007 at 9:40 AM
JOHNNYEJ
Brake fluid at normal level.
Jul 17, 2007 at 9:42 AM
BRUCE HUNT
  • 3,754 POSTS
If the fluid stays at the same level and does not drop I would suspect the booster.
Jul 17, 2007 at 9:43 AM
JOHNNYEJ
Thanks Bruce, Where is the booster located and is this a possible FIY project?
Jul 17, 2007 at 9:45 AM
BRUCE HUNT
  • 3,754 POSTS
The booster should be behind the master cylinder. I would look at the vacuum line for any problems. Leaking is my suspicion.
Jul 17, 2007 at 9:50 AM
JOHNNYEJ
Thank you, I'll check it out.
Jul 17, 2007 at 9:51 AM
Suggested Repair
With brake fluid level staying normal, inspect the brake booster vacuum line behind the master cylinder for leaks. If the line is sound, suspect the brake booster.
Conversation Summary
The owner of a 1990 Honda Accord reports brakes that become very soft and bottom out when the A/C runs in hot weather, but work normally when it is cool. Fluid level is normal. The expert suspects a vacuum problem at the brake booster and recommends checking the vacuum line behind the master cylinder for leaks.
