2001 Honda Accord Idle Knocking Noise
JACKIEVARGAS
'01 Accord. 68,000 miles. Automatic. 2 wheel dr. making a slight knocking or ticking noise under the hood. It doesnt always occur, but when it does, its when I'm at a stop sign/traffic signal. basically whenever the car is in drive but my foot is on brake. It is sometimes accompanied by a breif series of sputters, as if the vehicle is about to turn off. When the light turns green and I accelerate, the ticking stops; it will also stop if I put it in nuetral. Its very strange but it doesnt always happen. Any ideas?
Jul 26, 2007 at 5:23 AM
BRUCE HUNT
  • 3,754 POSTS
I think the sound is an injector. The injector might not be functioning correctly or fully spraying the fuel it is supposed to. I suggest when you have time and hear the sound that you take a screwdriver and put the tip near each injector and put your each against the handle to listen. You might be able to pinpoint where it is coming from.
Jul 26, 2007 at 5:40 AM
Suggested Repair
Suspect a fuel injector that is not spraying fully. When the ticking occurs, use a screwdriver as a listening tool at each injector to pinpoint the source.
Conversation Summary
A 2001 Honda Accord with 68,000 miles intermittently ticks or knocks under the hood while stopped in Drive with the brake applied, sometimes with brief sputtering. The noise stops when accelerating or shifting to Neutral. The expert suspects a faulty fuel injector and recommends listening at each injector with a screwdriver to locate it.
