last week i have installed a new (used) engine for my car listed above ivtec dohc.after driving for 10 minutes, I had a problem, it cuts off and in scanner i read this : and the engine burned 2 quartz of oil in 5 days! i replaced the VTEC Oil Pressure Switch, but i had not a good result. so I replaced again the engine. and I had the same problem, and i replaced the VTEC Oil Pressure Switch, but i had not a good result, in addition I have now two new codes: so, do you think that the mechanics made something wrong in wires ? or what could it be ? thank you
Mar 16, 2021 at 10:54 AM
