Honda Door Locks and Electric Windows
LISA
The electric door locks have quit on my 98 Honda Accord.At the same time the electric windows on the passenger side can't be control from the the drivers door. They work fine from each door control.Do you have any suggestions?
I cheched all the fuse under the hood and the two fuse panels on the side of the dash by the doors. They were ok. any other ideas?
Jan 1, 2007 at 4:38 AM
BRUCE HUNT
  • 3,754 POSTS
You can check the fuses, but I suspect that they are going to be fine. However, start there. Make sure that you look under the hood at the fuses as well.
Jan 1, 2007 at 4:53 AM
BRETR
From a previous post "I had to replace all four window switches on an Accord ....... The switches themselves have di-electric grease on the terminals inside the switch assemblies. When it is cold, the grease is thick enough to still help the terminals make contact, but when the grease warms up, the terminals don't get any contact. Replace the driver's switch and go from there". These switches do wear out. If they all stopped at once I'd check the drivers side switch first. This is the master. Could be the switch connector has pulled loose
Jan 15, 2007 at 1:33 PM
