honda cooling fans
ANISHIYAMA
94 honda accord lx, 168000 miles and 4 cyl.
my car is overheating . one of the cooling fans doesn't run.
is there a fuse i should check first before replacing the fan?
i just got a new radiator and overflow bottle put in.
Jan 26, 2007 at 5:21 AM
BRUCE HUNT
  • 3,754 POSTS
Yes I believe there is a fuse, there are always fuses. Before running off to get a new fan, run the wires from the fan with the help of a piece of wire to the battery and test the fan. If it runs then you have temp sensor that is failing.
Jan 26, 2007 at 6:42 AM
