Honda Accord EX surges at speed
HEADBC
  • 5 POSTS
My 1992 Honda Accord EX surges at speed. At 2600RPM and 65 MPH the RPMs will surge up 300-400 RPM without the speed increasing. Any ideas?
Jan 22, 2007 at 1:22 AM
BRUCE HUNT
  • 3,754 POSTS
While driving at say 60 mph, the engine will rev higher and raise the rpm with out affecting the speed of the engine.
First, of all if this is correct, is the engine truelly reving or is it a false reading by the tach?
Is this an automatic or manual tranny?
Jan 22, 2007 at 2:33 AM
HEADBC
  • 5 POSTS
Automatic transmission.
I can hear the engine RPMs increase. The actual speed and rpm surge is an estimate, but close. I do not think it is a false indication.
Jan 22, 2007 at 2:41 AM
BRUCE HUNT
  • 3,754 POSTS
But bottom line is the engine does not go faster but the engine will raise in rpm. Right?
Or is the issue the unsteady spead of the engine?
Does the car have cruise and will it hold the speed steady?
Jan 22, 2007 at 2:52 AM
HEADBC
  • 5 POSTS
Yes, it has sc. When it is engaged it holds speed steady.
The engine speeds up but the car does not accelerate.
RPMs go up from 2600 to 3000 roughly.
I have an issue with my battery, maybe the charging circuit. Could these be related?
What if the O2 heater isn't working properly????
Jan 22, 2007 at 3:21 AM
BRUCE HUNT
  • 3,754 POSTS
I have to sort through this rpm increase but no speed increase. This would indicate that there is a slippage in the transmission. IF the engine surges and the transmission is fine, the car will try to speed up. It may not be overly noticeable but it should try to increase the speed. Do you agree with this? Now, is the tranny giving any other indications of slippage? Why is it the cruise can hold it steady?
Jan 22, 2007 at 5:27 AM
HEADBC
  • 5 POSTS
The transmission was re-built about 2 yrs ago. I haven't had any problems with it. It shifts through all 3 gears just fine.
Jan 22, 2007 at 6:06 AM
BRUCE HUNT
  • 3,754 POSTS
I am still confused here. You run the pedal and the car will surge the engine rpm but not the speed of the vehicle. Cruise runs the pedal and everything works fine. Right? Help me out here as there is no logic behind this.
Jan 22, 2007 at 9:19 AM
