2003 Honda Accord Floor Floods in Rain
GSVER140
I have a Honda Accord model 2003, 26000 miles, V6 engine.
When it rains the floor is just flooded with water, mainly the passangerside and back seats floors.
I tried to hose the car and found out that when I put water on/below the front windshield, water basicly flows into the car floor creating a poddle on the floor.
I saw somewhere that there should be a drainage hose from the bottom of the windshield an to the bottom of the car, I can not find it. But when I put water on the windshield the water comes down on bots sides of the car, somewhere behind the front tires, but I see no hose line there.
What can I do, can you help?
May 28, 2007 at 2:31 AM
BRUCE HUNT
  • 3,754 POSTS
You are going to have to get down and dirty to crawl under the car. The hose should be in the line directly below the air intake beneath the windshield. I believe that the drain favors the passenger side of the car. Good luck!
May 29, 2007 at 3:52 AM
Suggested Repair
Crawl under the car and locate the windshield drain hose in the line directly below the air intake under the windshield. It typically favors the passenger side; inspect and clear that drain so water does not enter the cabin.
Conversation Summary
The owner of a 2003 Honda Accord with a V6 said rainwater floods the passenger-side and rear floors, and water applied at the windshield flows into the cabin. They could not find the expected windshield drain hose, though water exits behind the front tires. The expert advised crawling underneath and checking the drain line directly below the air intake under the windshield, noting it usually favors the passenger side.
