2002 Honda Accord windshield washer light stays on
JON GO
Electrical problem
2002 Honda Accord 6 cyl Two Wheel Drive Automatic 171 00 miles
My windshield washer light has all of a sudden stayed on even when the fluid is full,please advice whats the best thing to do.the other issue is with the drivers side turning signal sometimes it works sometimes it doesnt
Mar 2, 2009 at 1:03 PM
ZACKMAN
  • 4,202 POSTS
Locate your washer fluid bottle. At the bottom of the bottle, you will see a sensor attached to it. Unplug the wire harness. Check voltage between the two wires. You should have about 12 volts. If you have 12V, make sure that the sensor is tightly connected to the the wire harness. Replace sensor is voltage is less than 12.
With intermittent turn signal, before ruling out the turn signal switch, try replacing the turn signal flasher...
Mar 2, 2009 at 5:36 PM
