Honda Accord 2003 DX drive belt
2003 HONDA ACCORD
FOREIGNER
Dear 2CarPros. Will you give, please, advice to how change the drive belt on Honda Accord 2003 DX(basemodel: 4cl, 4 door, 2.4l engine, 80,000km)?
Thank you in advance
V. Kvartler
Mar 18, 2007 at 4:03 AM
BRUCE HUNT
  • 3,754 POSTS
What are you calling the drive belt? Is it the timing belt?
Mar 19, 2007 at 6:41 AM
FOREIGNER
It is the belt that is outside the engine and is connected to alternator and engine.
Mar 20, 2007 at 2:08 AM
BRUCE HUNT
  • 3,754 POSTS
I am emailing you a diagram and text that should help. It actually is referencing the adjustment of the tension on the belt but you need to loosen in order to tighten the tension and you just loosen it remove and put on new. Then the tensioning part should be informative as well.
Mar 20, 2007 at 2:32 AM
