1999 Honda Accord Idle Drop and White Smoke
CHARLIEDUB
Was wondering if you could help me out!!!! I have an Irish Honda Accord 1.8 v tec when I start the engine either hot or cold the revs drop down to the point that the car nearly cuts out then it pulls itself back up to normal any idea what the problem could be?
Hope you can help
Charlie.
Dublin
Ireland
Jan 16, 2007 at 7:08 PM
BRUCE HUNT
  • 3,754 POSTS
Not too familiar with that engine. What is the year of the vehicle?
Jan 17, 2007 at 6:06 AM
CHARLIEDUB
Hi Bruce thanks for getting back to me. Its a 1999 the european model 1.8 v tec I also need a little help on something elso. I ve been told the due to the high tempeture the v tec engines run at the white smoke comming from the exaust is normal its not excesive but when idle there is always a good flow of white smoke???
Hope to talk to ya soon
Charlie.
Jan 17, 2007 at 9:55 PM
BRUCE HUNT
  • 3,754 POSTS
Do yourself a favor and honestly determine if the car uses anti-freeze. The amount it uses can be small but should be steady. The whitle is NOT normal. Don't let anyone sell you that bill of goods.
The hesitation can be the vehicle trying to run on a mixture of water and gas. They don't like it. Is there a small but noticeable loss of power in the vehicle?
Jan 18, 2007 at 5:56 AM
Suggested Repair
Check whether the engine is steadily using coolant. White exhaust smoke is not normal and may mean coolant is entering the combustion chamber; that can also cause the idle drop if the engine is running on a water and fuel mixture. Note any small loss of power.
Conversation Summary
The owner of a 1999 European Honda Accord 1.8 VTEC says the revs drop nearly to stall after hot or cold starts, then recover, and that white smoke is always present at idle. The owner was told the smoke is normal because of high operating temperature. The expert says white smoke is not normal, advises checking for steady antifreeze use, and suggests the hesitation may come from running on a mix of water and fuel. The expert also asks whether there is a small loss of power.
