1994 Honda Accord Rough Idle
FISHER
I have a 1994 Honda Accord. 4 cyl with 138,000 miles. It runs very rough at idle. Once I give it gas and its going it runs very well and has normal power/ On th road you would never know it had a problem till you come to a stop and it starts shaking.
Jan 16, 2007 at 8:50 AM
MIKEB623
  • 13 POSTS
If it does this at idle it may be a worn engine mount. My 92 accord does it very roughly in reverse when cold and at idle in drive. Another tell is if your car also shifts a little rough.
Jan 16, 2007 at 1:27 PM
MATHIASO
  • 1,209 POSTS
Check for faulty coil, incorrect ignition wiring,inspect intake manifold gasket and vacuum hoses.
Jan 16, 2007 at 4:01 PM
BRUCE HUNT
  • 3,754 POSTS
Let me add an easy and typically free check. Take the EGR valve off and clean it.
Jan 17, 2007 at 2:31 AM
Suggested Repair
Check the ignition coil and wiring, inspect the intake manifold gasket and vacuum hoses, and remove and clean the EGR valve. A worn engine mount is another possible cause of idle shake.
Conversation Summary
A 1994 Honda Accord with 138,000 miles runs roughly and shakes at idle or when stopped, but runs normally with good power while driving. Suggestions included a worn engine mount, a faulty coil, incorrect ignition wiring, intake manifold gasket or vacuum hose leaks, and cleaning the EGR valve.
