HELP! windows, dashboard, clock all get no power
TIPZJAMES
This is my first post ever, BUT I need Help bad! ok my radio got stollen a week ago, last night I got a new harness and radio and the Red 12v power cable was dead (checked w/ a multimeter).....I though it was broke pulled loose or somthing, so I just used the yellow (always on) 12v got everything hooked up...working fine, right? Well not quite....now my power windows are dead, all my dummy lights, speedometer, my seat, clock, and i think thats it. Then all the sudden the red 12v worked (checked w/ multimeter)....ALL at the same time. Then about 2 hrs later the red wire was dead again. All the fuses checked fine and hell I even replaced them. I dont think it has anything to do w/ a broke or crossed wire, they all seem secure , and I took the new radio out. HELP?!?!?! BTW its a Accord 96 EX
Jul 31, 2007 at 3:58 PM
BRUCE HUNT
  • 3,754 POSTS
The radio is a key element. Now, did the thief disconnect the radio or pull it or cut it out? That red wire is important and I really think it has been damaged.
Aug 1, 2007 at 1:04 AM
TIPZJAMES
[quote:54ac5c5641="Bruce Hunt"]The radio is a key element. Now, did the thief disconnect the radio or pull it or cut it out? That red wire is important and I really think it has been damaged.[/quote:54ac5c5641]
It was disconnected, so all the wiring to the oem honda radio plug is in tacked, Im thinking because of the timing with me putting in the radio that its something I did, and I know that normally many things share a ground or relay but I dont know where or how to check
Aug 1, 2007 at 3:08 AM
