Help urgent, 2005 Accord, AC Condenser, Radiator,Coolant
UNKNOWCAR
Hey all friends,
I need all your help.
I bought 2005 new Honda Accord on September 2005 with 3 year warranty.
On November, I found out AC did not work, I brought the car to dealer. Dealer said AC Condenser is broken(rock hit it) and this damage is not in the warranty. At that time I did not get time to fix it.
February 9th of 2006, in the morning I found the coolant leak, I brought it to the same dealer again.
But they told me that the coolant leak because of the AC Condenser. Now the problem of the car is AC Condenser broken, radiator broken, coolant leak, gasket of engine head broken.
I do not know anything about the car. I just feel very confused that how does AC broken affect coolant leak after 3 months later. Should I trust the dealer?
they still said this is not under the warranty. What can I do? Please help!!! :? :( :cry: :cry:
Feb 9, 2006 at 3:47 PM
FISHERMAN
  • 937 POSTS
First at all, Hi!
Then:
The a/c condenser its behind of the radiator, (side to side) i think when the rock hit the condenser broke the radiator to, the guys at the dealer should told you that the radiator was broken and you should stop using your car inmediatly or get fix it right away, because the leak on the radiator can kill your engine (your head gaskets).
(the radiator leak possibly was so small that took so long to empty it)
Im just guessing!
What do you think?
Manuel.
Feb 10, 2006 at 1:08 AM
