1985 Honda Accord Coolant Backup
MONKEYBOYOHOHOH
I have a 1985 honda accord with around 220000miles on it. Recently the coolant has been backing up into the reserve tank. What is causing this to happen? At the same time the car is running really rough as if it wants to seize on me and is emmitting a lot of white colored smoke. What is causing this? Are the problems related?
Mar 1, 2007 at 5:27 AM
BRUCE HUNT
  • 3,754 POSTS
Yes they are related. The pressure in the system is more than it should be because the car's compression is leaking in to the cooling system. You have a head gasket that is leaking or failing. You need to have the head removed, checked for warpage and cracks and then a new head gasket installed. That should take care of both.
Mar 1, 2007 at 5:41 AM
Suggested Repair
Remove the cylinder head, inspect it for warpage and cracks, and install a new head gasket.
Conversation Summary
The owner of a 1985 Honda Accord with about 220,000 miles reports coolant backing into the reserve tank, rough running, and heavy white smoke, and asks whether the problems are related. The expert says compression is leaking into the cooling system from a failing head gasket and recommends removing the head, checking it for warpage and cracks, and installing a new head gasket.
