heat problem
ERVIN77
I have a honda accord 1996 when i turn on the heat I get no hot air what could be wrong, i just changed the radiator 2 weeks ago
Sep 18, 2007 at 7:36 AM
BRUCE HUNT
  • 3,754 POSTS
Check the coolant level and did you purge the cooling system of air? you need to make sure the coolant level is full and then when the engine is warm do both hoses get hot that feed the heater?
Sep 18, 2007 at 11:49 AM
