1997 Honda Accord Fuel Gauge Stuck Full
LEEWMEISTER
I just picked up a 1997 Honda Accord EX Wagon with 108k. The fuel gauge always shows full. That would be nice, but I know it's not true. I haven't had a chance to check yet, but I'll start at the fuse box. Does anyone have a suggestion on how to trace the problem if it is not a fuse?
Thanks.
Oct 25, 2006 at 7:21 AM
BRUCE HUNT
  • 3,754 POSTS
Get a manual for the car. Cheap from parts store and that should give some direction. The sender from the tank passes an electrical charge to the gauge. The guage itself could be stuck. I have experienced the failed gauge which is the easiest to remedy. The cluster can be bought from a junk yard and the individual components taken out.
Oct 26, 2006 at 1:12 AM
LEEWMEISTER
Thanks Bruce. I do plan on picking up a manual. I only got the car on Tuesday and haven't had much opportunity to play around with it yet.
Oct 26, 2006 at 2:02 AM
Suggested Repair
Consult a service manual for the fuel-gauge circuit. The tank sender sends a signal to the gauge; a stuck or failed gauge is a common cause and can be replaced using the gauge from a used instrument cluster.
Conversation Summary
The owner of a 1997 Honda Accord says the fuel gauge always reads full and plans to check the fuse box. The expert recommends a service manual, explains that the tank sender feeds the gauge, and notes that a stuck or failed gauge is often easiest to fix by taking the gauge from a junkyard cluster.
