1999 Honda Accord Stalls When Slowing
AVIS
1999 Honda Accord. mileage:90550. The engine stalls suddenly for no reason, mostly occurs in the morning when i slow down to take a turn or near a speed bump. It also stalls when i stop in signal after little chugging like misfire. It starts up immediately when i crank again.I replaced the fuel lines, ignition wires,spark plugs and also tried the Honda safety recall 1997-99 HONDA IGNITION SWITCH - which is similar to my issue. But still the problem is not resolved, Fear to take the vehicle in speedway nowadays.Any help will be appreciated. Thanks
Mar 21, 2007 at 8:53 AM
BRUCE HUNT
  • 3,754 POSTS
Check the EGR valve - clean it. Are you getting a check engine light? When you did the fuel lines did you replace the fuel filter?
Mar 21, 2007 at 10:00 AM
AVIS
[quote:37cf5dc5a6="Bruce Hunt"]Check the EGR valve - clean it. Are you getting a check engine light? When you did the fuel lines did you replace the fuel filter?[/quote:37cf5dc5a6]
Fuel filter is not changed.Yes, check engine is on with a DTC- P1457.I was told that is not related to this problem and will not harm engine also. So i did not fixed that.
Mar 22, 2007 at 2:17 AM
BRUCE HUNT
  • 3,754 POSTS
P1457
A very common late 90's code, P1457 is a failure in one of the evap system solenoid valves. There are 2 culprits, the Vent Control Valve & the 2 Way Bypass Valve. They are located under the vehicle, roughly below the left rear seat area. They short out due to corrosion/contamination from water seeping into the valves. I changed both, but the real culprit seems to be the 2 Way bypass Valve.
Mar 22, 2007 at 4:50 AM
AVIS
Thanks for your help on this. Is this EVAP valve causing the engine stall or there may be another code that will show up only after fixing P1457?
Mar 22, 2007 at 4:08 PM
BRUCE HUNT
  • 3,754 POSTS
I won't say for sure, but I think the answer is yes.
Mar 26, 2007 at 2:40 AM
Suggested Repair
Clean the EGR valve and replace the fuel filter, which has not been changed. For code P1457, inspect and replace the EVAP vent control valve and two-way bypass valve under the left rear of the vehicle; corrosion from water intrusion is common, and the two-way bypass valve is the more likely failure. The expert believes this EVAP fault may be related to the stalling but is not certain.
Conversation Summary
A 1999 Honda Accord with about 90,550 miles stalls when slowing for turns or speed bumps and after slight misfire-like chugging at stops, then restarts immediately. Fuel lines, ignition wires, spark plugs, and an ignition-switch recall repair did not fix it. The expert advised cleaning the EGR valve and asked about the fuel filter and check-engine light. The owner reported code P1457 and an unchanged fuel filter. The expert identified P1457 as a common EVAP solenoid failure, especially the two-way bypass valve, and thought it could be causing the stall but was not certain.
