I have a 93 Honda Accord SE. The seals around the spark plugs were leaking and soaked the spark plug wires. This made the engine shake and feel like turning off. I have replace the spark plug seals and spark plug wires and this seemed to help. I was told that the map sensor also need to be replaced otherwise it would begin to shake again. Is this true? Does anyone know if what I am told is correct? I thought that the map sensor only controlled the amount of air that goes into the engine.
Apr 12, 2006 at 5:49 PM
