Electric Windows
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the window mechanism inspected and its supply and ground tested under load before choosing a motor or regulator. Use the correct door-trim procedure for the wagon.
Guidance references and applicability
Source: Original question and visible replies. Owner outcomes are attributed; other participants' experiences are not treated as this owner's repair. Next steps are editorial guidance, not a confirmed diagnosis. Fluke: Voltage-drop diagnosis. General electrical testing; no vehicle-specific diagnosis. https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting
Discussion summary
Electric Windows
The front windows of a 1994 Accord wagon became very slow, especially the driver's window. Lubricant had not restored normal operation, and the owner could not remove the door trim.
Reported outcome: No repair or follow-up result was reported.
A reply blamed worn motors, but no circuit readings or mechanical inspection established the cause. The discussion did not provide a verified trim-removal procedure.
