1990 Honda Accord Distributor Seal Leak Fix
STRWBRYSHRTCK211
'90 Honda Accord. about 220k. auto. I had my car checked out to see where my oil leak was. they said i needed to replace my oil pan gasket and the distributor seal. i know how to fix the oil pan gasket, but where does this distributor seal go? i'm assuming that after i get the pan off it might be somewhere up there but i cant fix it til i know. help.
Sep 5, 2007 at 9:44 AM
MERLIN2021
  • 17,250 POSTS
The distributor is the ignition part with spark plug wires coming out of the top. Remove it and replace the seals!
https://images.2carpros.com/forum/automotive_pictures/62217_90_Dist_copy_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Seals_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_30961_mitchell_2_10.jpg
Sep 5, 2007 at 10:07 AM
Suggested Repair
Remove the distributor—the ignition component with the spark plug wires—and replace its seals. Also replace the oil pan gasket as diagnosed.
Conversation Summary
The owner of a 1990 Honda Accord with about 220,000 miles was told an oil leak required an oil pan gasket and a distributor seal, and asked where the distributor seal is located. The expert explained that the distributor is the ignition part with spark plug wires and that it should be removed so the seals can be replaced.
