determining next course of action
REDSEN78
My name is Tom I have a 91 Accord LX 2.2L gen4 inline 4 cyl. with 179,000mi. Picked the car up for $500 was running with minor mechanical and asthetic issues. engine has oil leakage and white smoke in start and in accelleration. I replaced all belts @ same time during major tune-up. I could tell the timing was off alittle, but car ran faster with higher than normal torque output so I left it alone. Now the other day car started overheating, I replaced thermostat & waterpump (still overheating) My oil is not milky my coolant shows signs of oil contamination. Basically can I retime properly to fix or have i blown the head gasket or something to that extent. I,ve done almost everything to fix personally owned vehicles and have learned alot I have not done an all points rebuild yet although I am considering my first. I'd really like to see some rebuild pics and vids any where online but can"t seem to find much, and I don't want to pay the (wrong) paysite trying to find tutorials any recomendations
Oct 27, 2007 at 6:53 AM
  • 75,988 POSTS
Sounds like you blew something inside-see below
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Find out what's broken it can get expensive.
Oct 27, 2007 at 7:11 AM
