1992 Honda Accord D4 Light Blinking
AANDERSEN
1992 Honda Accord, 190,000 miles, don't know engine size.... My car recently started acting funny, the D4 Indicator Light started blinking no matter what gear I'm in. It starts out driving fine in first gear, but when it shifts to second, it does not want to accelerate, especially going up a hill (it only goes 20 to 25 MPH up a hill). When I am driving the RPMs stay at 2000 as long as my foot is on the gas, when I coast it goes down to around 1500 RPM. When I am stopped, it idles at 200 RPM. The owners manual says that when the D4 indicator Light blinks like that it indicates a transmition malfunction. My question is, what kind of malfunction could it be? And how much would it cost to fix? I don't think it is worth fixing if it is seriouse, but this car has lasted me quite some time and if it is something simple, I'd like to keep it running.
Apr 30, 2007 at 7:49 AM
BRUCE HUNT
  • 3,754 POSTS
Have you done the obviouse and checked the transmission fluid level and the color of the fluid? Try that first.
Apr 30, 2007 at 9:34 AM
AANDERSEN
The fluids are fine, I actually took my car into the shop and had it scanned. There are still a few codes I am not sure about, but the main thing was the shift selenoid and a relay to the computer had to be replaced.
May 23, 2007 at 8:01 AM
Suggested Repair
Check transmission fluid level and color first. If the fluid is fine and scan codes remain, replace the shift solenoid and the relay to the computer as the shop indicated.
Conversation Summary
The owner of a 1992 Honda Accord reported a blinking D4 light, weak acceleration after the shift into second, and unusual RPM behavior. The manual links a blinking D4 light to a transmission fault. The expert advised checking fluid level and color first. The owner said the fluid was fine and a shop scan indicated the shift solenoid and a computer relay needed replacement.
