2004 Honda Accord oil drain plug
66,000 MILES • 4 CYL • 2WD • AUTOMATIC
DSUEHIRO
the car manual said a special tool is required to remove the case oil drain plug is this true?
I can't remove the plug and I just put wrench loosen on the plug?
Can you help?
Nov 13, 2009 at 7:56 PM
SERVICE WRITER
  • 9,123 POSTS
LOL....There are lots of "special tools"
A regular metric wrench is all you need. somewhere in the 15-17 mm range. Might want to get a washer for the drain plug ahead of time. The hondas are usually replaced on an oil change, but it may be fine to be reused.
Nov 14, 2009 at 12:37 AM
DSUEHIRO
Have a wonderful weekend
Nov 14, 2009 at 12:47 AM
