Cold Start Problems
DGCHURCH
1993 Honda Accord; 105,000 mi; 2.2L 4 cylinder.
When starting cold after the car has sat for more than 5 hours it turns over strong but takes 4-5 seconds to start. After the initial start for the day, it starts instantly thereafter. Is this normal or a precursor to a problem? Any thoughts on what may be creating the issue?
Thanks.
Apr 24, 2007 at 8:38 AM
  • 75,988 POSTS
[quote:85ee20db73="dgchurch"]1993 Honda Accord; 105,000 mi; 2.2L 4 cylinder.
Thanks.[/quote:85ee20db73]
Last major tuned-up? also have the coolant temperature sensor check.
Apr 24, 2007 at 10:16 AM
DGCHURCH
[quote:ca03f917bc="rasmataz"][quote:ca03f917bc="dgchurch"]1993 Honda Accord; 105,000 mi; 2.2L 4 cylinder.
Thanks.[/quote:ca03f917bc]
Last major tuned-up? also have the coolant temperature sensor check.[/quote:ca03f917bc]
Last major tune up was at 94,500; 10/06. All the major items have been done pretty recently: timing belt, radiator, tranny, brake fluid flushes, etc... Anything other than the coolant temp sensor, you can think of? Thanks again; much appreciated!!
Apr 24, 2007 at 10:57 AM
LOSTINMARS
  • 222 POSTS
the pgm-fi relay is probably starting to go bad. very very common when the weather starts to warm up. it located under the driver's side of the dash near steering column.
Apr 27, 2007 at 1:10 PM
  • 75,988 POSTS
[quote:8cb29d15f7="dgchurch"][quote:8cb29d15f7="rasmataz"][quote:8cb29d15f7="dgchurch"]1993 Honda Accord; 105,000 mi; 2.2L 4 cylinder.
Thanks.[/quote:8cb29d15f7]
Last major tuned-up? also have the coolant temperature sensor check.[/quote:8cb29d15f7]
Last major tune up was at 94,500; 10/06. All the major items have been done pretty recently: timing belt, radiator, tranny, brake fluid flushes, etc... Anything other than the coolant temp sensor, you can think of? Thanks again; much appreciated!![/quote:8cb29d15f7]
Try looking for a cold start injector it might not be working that's if it has one.Further check the fuel pressure and the fuel pressure regulator operation-meaning with and without vacuum to it. Look for fuel in the regulator hose-its not suppose to be there ruptured regulator.
Good Luck
Apr 27, 2007 at 5:36 PM
