1986 Honda Accord Clutch Slip in Gear
JEFFHONDACCORD
86 honda accord 71k miles 2dr lxi 2.0l 4cyl
rpm increases dramatically in 3-4 gear when accelerator is pressed more than 1/2 way.... i was told clutch is slipping.... is this so?
also, are oem parts for this model much better than aftermarket???
Oct 9, 2007 at 3:33 PM
BRUCE HUNT
  • 3,754 POSTS
Yes that sounds like a clutch problem. I stick with OEM equivalent. 76K miles on the car and the age. Either a lot of town driving or someone rides the clutch pedal a bit. I would look at the driving habits.
Oct 10, 2007 at 5:59 AM
Suggested Repair
The symptoms match a slipping clutch. Replace it with an OEM-equivalent clutch and review driving habits, such as riding the pedal or heavy town driving, which can wear a clutch early.
Conversation Summary
The owner of a 1986 Honda Accord with about 71,000 miles reported engine RPM rising sharply in 3rd and 4th when the accelerator was pressed more than halfway, and asked whether the clutch was slipping and whether OEM parts were better than aftermarket. The expert agreed it sounded like a clutch problem, recommended an OEM-equivalent clutch, and suggested checking for town driving or riding the clutch pedal.
