Cluster lights not turning on?
1972JER
I just purchased a 99 honda accord LX, 4 cylinder. my cluster light don`t come on.brake,abs,srs,key light,doors signals,a/c ,interior lights, all that works goog.is just at night the the clusters don`t light,either the shifter and a/c night lights. i have cheked all the fuses and are not burned. what could be the problem and location. thanks
Apr 10, 2006 at 7:31 AM
LOSONE
  • 1,616 POSTS
Did you try adjusting the dimmer control on the dash?? Good luck
Apr 10, 2006 at 10:37 AM
1972JER
[quote:349d9ab79d="losone"]Did you try adjusting the dimmer control on the dash?? Good luck[/quote:349d9ab79d]
the dimmer control does not work either.that was the first thing i tried.is there a module or relay and where can i find it.
Apr 10, 2006 at 4:02 PM
