1995 Honda Accord CV Boot Clicking
QUIQUE
I have a 95 Honda Accord w/120,000 miles and I am attempting to change out the CV boot but am having difficulty, could you please give me advise on how to change out the CV boot? Thanks
May 29, 2006 at 5:08 AM
BRUCE HUNT
  • 3,754 POSTS
Was the car making any cllicking noises when the car turned a corner? If it was then don't bother with the boot replacement.
May 29, 2006 at 3:41 PM
GINGER48
88 Honda CRX Hf 217K miles
Hi, I had the same problem with my CRX. Mine was making the clicking noise pretty badly so I ended up changing both driveshafts at the recommendation of the autoshop owner. Is this what you would have recommended too instead of changing just the boot? Thanks for your help!
Jun 1, 2006 at 1:28 PM
BRUCE HUNT
  • 3,754 POSTS
Yes, once the clicking noise is present, no amount of grease or new boots are going to stop it. The shaft is going to progressively get worse. The new lube may stave it off for a short time but the worn areas will get worse. The effort to replace the boot is more work than replacing the entire axle.
Jun 6, 2006 at 12:29 AM
MMPRINCE4000
  • 8,548 POSTS
While you can buy boot kits for most cars, it is FAR easier to change the CV axle. Most CV axles (rebuilt) run $70 or so, while some boot kits are $40 and the labor is far more to change boots only.
Nov 13, 2010 at 10:45 AM
Suggested Repair
If the CV joint clicks while turning, replace the complete CV axle rather than only the boot. Once clicking is present, new grease or a boot will not stop progressive wear, and axle replacement is less work than a boot-only job.
Conversation Summary
The owner of a 1995 Honda Accord asked how to replace a CV boot. Experts advised that clicking while turning means the joint is already worn, so a new boot will not fix it and the axle should be replaced instead. A follow-up about a 1988 Honda CRX with clicking received the same recommendation.
