buzzing noise
SOUTHCALIKING
  • 5 POSTS
I have a '96 accord that has recently started making a buzzing noise upon starting the vehicle for about 5-10 seconds coming from the front left corner- which was damaged in a collision before i bought the vehicle. this buzzing does not change when i increase rpm's during this time. the buzzing will then occur intermittently for 1-3 seconds seemingly at random. after the engine is warm- it doesnt occur on start up. can you please help me to narrow down the source of this noise?
Sep 8, 2006 at 12:39 AM
BRUCE HUNT
  • 3,754 POSTS
Have you checked to see if the noise occurs when the brakes are applied? What size engine?
Sep 8, 2006 at 3:43 AM
SOUTHCALIKING
  • 5 POSTS
its a 2.2L vtec. and yes i apply the brakes when i start the engine and keep them depressed. the noise starts right after ignition- i have tried to increase rpms as well and niether have any effect- it seems to be separate from the main engine systems. the noise will then rarely reoccur at random- maybe the pump for the wiper fliud?
could it make noise somehow- the fluids still spay on the windshield... thnx
i wanna say it sounds like some sort of pump or actuator or something- but i would just be guessing
also i have put it in drive right away and started moving and the noise will continue for 5-10 seconds with no brake pressure
Sep 8, 2006 at 2:29 PM
