2001 Honda Accord Brake Cost
JILLYCHIK
I have a 2001 Honda Accord LX 4 door 4 cyl....I just found out that I need to have the brakes replaced.....the shop said my rear brakes are gone and I only have 15%-20% of the front brakes. How much should each, the front & the rear, cost? We are new to the area and do not have a reliable mechanic yet. I want to be sure that we dont get ripped off. Thanks so much!
May 3, 2007 at 3:54 AM
BRUCE HUNT
  • 3,754 POSTS
If the rear brakes are gone, it is possible that you might need a new rotor or two at about $20 - $25 each plus the pads at $18 - $60. Same in the front with pads at $5 - $20 higher in cost. Labor on the job should be around 2.5 - 3.5 hours.
May 3, 2007 at 4:53 AM
Suggested Repair
Plan on rear brake pads and possibly one or two rotors, plus front pads that cost a bit more; rotors were estimated at about $20-$25 each, rear pads at $18-$60, and labor at about 2.5-3.5 hours.
Conversation Summary
The owner of a 2001 Honda Accord was told the rear brakes are worn out and the front brakes have only 15-20% remaining, and asked typical front and rear costs. The expert estimated rotors at about $20-$25 each, rear pads at $18-$60, front pads $5-$20 higher, and labor of about 2.5-3.5 hours.
