[quote:8534d04f81="Bruce Hunt"]Truthfully, NO. The rotors were turned or replaced?
New rotors are about $40 or so each and pads run around $20 to $60 for a set of two. Installation takes about 30 minutes. Good money. I would want to know if the rotor was turned or replaced because experience with Honda is that the turning of the rotors is almost as waste of time. Replace them to eliminate pedal flutter as they are weaker and more prone to warpage.[/quote:8534d04f81]
actually if you knew the brake setup on this car you would know its fair. pads from honda are $60 turn rotors $25 or so each, although i would of replaced them, and labor should be about $220 or so based on about 3.5 hours of labor.
you have to take the front bearing apart on this model to remove the rotor and this requires removing the steering knuckle.
Mar 5, 2007 at 1:09 PM
